I noticed lately that sometimes when I have several properties marked as logged they create two rows in value stream which differ in timestamp in +-15ms.
There is a service that parses json and writes ints,numbers,bools and a datetime into a Thing.
Is there something I can do about it? (I know I can solve it with a Stream as well, but ValueStream was sufficient so far)
Thank you for your suggestions
Jara
Hello, Jaroslav.
Looking at the article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS258414 I don't see anything that matches up with what you're describing. Are there actually duplicate entries in the log?
Export the Thing in question here and attach it, if possible.
-- Craig A.
Hi Craig,
here is the Thing template.
Hi, I am having the same issue, did you solve the problem ?
