Export and Import data in a cloud version of composer
  • August 7, 2018
  • 2068 views
How to export and import data in a cloud version of composer since it is not installed locally there is no thingworxStorage?
    Hi @Priyadharshini is this hosted with PTC Cloud Services? or are you referring to your own cloud installation of ThingWorx? Also how exactly are you looking to perform the import / export? Via the composer UI or via the FileTransfer Thing?
    Yes it is hosted with PTC Cloud Services.I want to export FileTransfer Thing from the local host and import to my thingworx composer
     https://wb2smhhf.studio-trial.thingworx.io/Thingworx/Composer/index.html
    Priya
    based on your login account for the hosted instance I think you should be able to import using the Import function
    If in case this is not visible for you, you may want to reach out to ThingWorx Administrator to allow this for your profile.
