Can anyone please explain me the differences and when to use which one with example? I have read few articles on this topic but still its not clear to me. I would request you to give an use case scenario. Thanks.
We have TWX tutorials video to introduce value streams / streams:
In summary:
Streams are used when you want to combine a specific set of data over time from different sources. And if you are looking to record data over time paired with other relevant data points.
In summary:
Hi @RajatBain ,
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Abhinav
