I've been using a ValueDisplay widget to display .JPG images from a Thingworx Repository.
It works well with the Value Format [Renderer and State] set to "Display image to cover cell height"
in versions 9.4.3 and 9.4.7.
After upgrading to version 9.5.3 the images display as a microscopic postage stamp.
The only way for the .JPG images to display in a size big enough to see is to change the Renderer and State to "Display image using original size".
Original size does not resize with the browser.
Hello @LynnM , The issue you encountered and is being reported as fixed in ThingWorx version (9.7.0, 9.5.7, 9.6.4) I believe these versions are available for download.
Pehowe
@LynnM , There was a similar issue reported in 9.2.1. It was fixed in 9.3.4.
If you are seeing this issue. Create a simple test case (being able to demo a problem gets a better response) and open a case with Support.
Thank you
I’ve opened Case 17482777
@LynnM , The items has been identified as a defect, R&D is investigation the issue. As updates are made available, additional information will be posted.
@LynnM , I did a review of the R&D issue, Based on the information available it looks like an updated is scheduled for the second quarter of calendar year of 2025.
Thanks for the update 8-)
Pehowe
