The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Is there a way I can view system objects (Mashups and Things) to duplicate or access the scripts. I tried with Administrator account but doesn't work.
You can duplicate the System Mashups without issues:
1. Go to Mashups
2. Do Advanced Filtering Enable "Show System Objects"
3. Search for the desired System Mashup
4. Select the desired System Mashup (with the left checkbox)
5. Click on top Duplicate button
All this done with the Old Composer :P
System objects "scripts" (ThingTemplate / ThingShape ) are usually written in Java and you can't see it (Well you can decompile ThingWorx Java Solution, but it wan't be useful to replicate it on Javascript as it's Java).
For System Mashups, just duplicate it and you will be able to see it everything.
I only need to duplicate the mashup and see the services. Example. UserMonitoringStatus mashup probably has some script services running. I would need to call them from my own Thing and modify output. Which user has the rights to do this because as Administrator I cannot duplicate.
1. Go to Mashups
@CarlesColl Thanks! I am used to searching in the top bar. You cannot duplicate from there. My bad.
