Visible property of a widget/label not working
VaibhavShinde
I have tried binding Boolean Property value to label widget but not working . using TWX 8.5.0
Hi ,
Thanks for reply,
Its Working fine now , the boolean property was not refreshing , when i bound it to refresh widget then its working fine.
Thank you
Hello @VaibhavShinde
Can you please provide more clarification so that i can help you with it. Have you bind boolean property from an entity to your label widget?
Om
Hi ,
Thanks for reply,
Thank you
