Dear experts,
What would be your suggestion on finding a way to visualize a 2-level Network in a Mashup? Are there any Widgets that give that kind of functionality out of the box?
Federico
We usually use the Tree widget to visualize networks.
Hi @PaiChung,
Can you provide a Network directly as an input? I couldn't find a way to achieve that right now. What I have seen is that Data should have a DataTable as an input if I'm not wrong. Would an arbitrary service giving a DataTable output be usable?
Federico
Networks have default services associated to provide the correct data and structure.
'GetNetworkConnections' for example will give you a child-parent relationship table of your network which can be mapped to your Tree widget.
I'm fairly sure this is something covered in the Thingworx fundamental courses as well, so I encourage you to check out the courses.
Hi @Raccone.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
