Want to include all columns in ThingWorx Analytics Model
jrajesh
I want to include all the columns except not the Goal in the Model. I am forced to create a Filter. Is there a way to include all columns.
Thanks and Regards,
Jyothi
nsampat
(To:jrajesh)
Jyothi,
What version of Analytics Server are you using?
It sounds like you encountered a known issue, where the Configuration Service was not run after installation of the Extensions.
Can you please take a look at this article: https://www.ptc.com/en/support/article?n=CS279917
And let me know if that resolves your issue?
Neel
3 REPLIES 3
nsampat
(To:jrajesh)
Jyothi,
Thank you for your post to the Community.
There should be a default filter, called "all_data" available to you for modeling jobs.
Regarding excluding the goal, you cannot exclude the goal from a modelling job, as it is required for the creation of the model.
Please let me know if this answers your question.
Neel
jrajesh
(To:nsampat)
Thanks Neel. But I am not able to see the all_data filter. When I click on Copy Definition from Existing Filter in the Create Filter dialog, I get an error.
Errors in Script Logs is
GetFiltersRowCountByDatasetAMS: Error: JavaException: com.thingworx.dsl.exceptions.DSLRequestProcessingException: Execution error in service script [GetFiltersRowCountByDatasetAMS] :: TypeError: Cannot call method "GetFilters" of null (GetFiltersAMS#14)
[message: Execution error in service script [GetFiltersAMS] :: TypeError: Cannot call method "GetFilters" of null (GetFiltersAMS#14)]
nsampat
(To:jrajesh)
Jyothi,
Neel
