Weather App with ESP8266
asanordontri
I try to connect a DHT22 sensor by ESP82266 and send the data to the Thingworx.
I tried to edit the Weather App with Arduino Uno Codes. I can connect the Thingworx server.
But I have been unable to show the data from the sensor in the Thingworx platform,
The Serial Monitor show the information as below
Connected to AndroidAP
IP address: 192.168.43.142
Thingwork Server connected
POST /Thingworx/Things/HTU21DThing/Services/setTempAndHumid?appKey=287b9c77-983c-4abf-9f75-4fc273c7183a&method=post&x-thingworx-session=true<&Temp=25.20&Humid=45.80> HTTP/1.1
Host: ohimvo0g.studio-trial.thingworx.io
Content-Type: text/html
POST /Thingworx/Things/HTU21DThing/Services/setTempAndHumid?appKey=287b9c77-983c-4abf-9f75-4fc273c7183a&method=post&x-thingworx-session=true<&Temp=25.20&Humid=45.70> HTTP/1.1
The Original Code.
https://www.thingworx.com/ecosystem/academic-program/iot-projects/weather-app-arduino-uno/
Here is my code that I have been using in ESP8266:
// Temp and Humid
  #include "DHT.h"
  #define DHTPIN 10     // what digital pin we're connected to
  #define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
//WiFi
  #include <ESP8266WiFi.h>
  const char* ssid = "AndroidAP";
  const char* password = "nslc3250x5589";
// The IP address will be dependent on your local network:
char server[] = "ohimvo0g.studio-trial.thingworx.io";
WiFiClient client;
//ThingWorx App key which replaces login credentials)
char appKey[] = "287b9c77-983c-4abf-9f75-4fc273c7183a";
// ThingWorx Thing name for which you want to set properties values
char thingName[] = "HTU21DThing";
// ThingWorx service that will set values for the properties you need
// See the documentation for this tutorial for more information
char serviceName[] = "setTempAndHumid";
//Initialize an HTU21D library object to read
// temperature and humidity data from your connected sensor
DHT dht(DHTPIN, DHTTYPE);
void setup() {
  // start serial port:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
//initialize HTU21D object to read values from sensors
   dht.begin();
  // start the Wifi connection:
Serial.println("Trying to get an IP address using DHCP");
  WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
void loop() {
  // Aquire sensor values
  float Temp =  dht.readTemperature();
  float Humid = dht.readHumidity();
  //through REST calls to your TWX server
  // if you get a connection, report back via serial:
  if (client.connect(server, 8443)) {
    Serial.println("Thingwork Server connected");
    // send the HTTP POST request:
client.print("POST /Thingworx/Things/");
client.print(thingName);
client.print("/Services/");
client.print(serviceName);
client.print("?appKey=");
client.print(appKey);
client.print("&method=post");
client.print("&x-thingworx-session=true");
client.print("<");
client.print("&");
client.print("Temp");
client.print("=");
client.print(Temp);
client.print("&");
client.print("Humid");
client.print("=");
client.print(Humid);
client.print(">");
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Content-Type: text/html");
    client.println();
    client.stop();
    // print the request out
Serial.print("POST /Thingworx/Things/");
Serial.print(thingName);
Serial.print("/Services/");
Serial.print(serviceName);
Serial.print("?appKey=");
Serial.print(appKey);
Serial.print("&method=post");
Serial.print("&x-thingworx-session=true");
Serial.print("<");
Serial.print("&");
Serial.print("Temp");
Serial.print("=");
Serial.print(Temp);
Serial.print("&");
Serial.print("Humid");
Serial.print("=");
Serial.print(Humid);
Serial.print(">");
Serial.println(" HTTP/1.1");
Serial.print("Host: ");
Serial.println(server);
Serial.println("Content-Type: text/html");
    Serial.println();
  else {
    // kf you didn't get a connection to the server:
Serial.println("the connection could not be established");
    client.stop();
I´d appreciate if anyone can help me, thanks.
I used the below script in an Adafruit Huzzah Feather to set a Thing Property value (PUT request).  I used a DS18B20 to get the temp, but it should be easy to reuse the code and just change out the source of the variable being sent to Thingworx.  You will need to update the following sections in the script:
<YOUR_WIFI_SSID>
<YOUR_WIFI_PASSWORD>
<THINGWORX_SERVER_NAME_OR_IP>
<THINGWORX_SERVER_PORT>
<YOUR_THING>
<YOUR_PROPERTY>
<YOUR_APP_KEY>
Code Starts Below-------:
/*******************   Libraries *************************/
#include <WiFiClient.h>
#include <OneWire.h>
#include <DallasTemperature.h>
/*******************   Temperature Sensor (DS18B20) Setup   ************/
// Data wire microcontroller pin
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
/******************   WiFi Setup   *********************************/
const char* ssid = "<YOUR_WIFI_SSID>";
const char* password = "<YOUR_WIFI_PASSWORD>";
const char* host = "<THINGWORX_SERVER_NAME_OR_IP>"; // ThingWorx Server IP Address
const int httpsPort = <THINGWORX_SERVER_PORT>;
WiFiClient client;
void setup() {
  Serial.begin(115200);
  Serial.println();
  Serial.print("connecting to ");
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());;
  // Start up the DS18B20 sensor
  sensors.begin();
void loop() {
  // Get the Temp from the sensor(s)
  sensors.requestTemperatures(); // Send the command to get temperatures
  // There is only one sensor connected, so get it from sensor index 0
  float tempF = sensors.getTempFByIndex(0);
  String strTempF = String(tempF);
  Serial.print("Temp: ");
  Serial.println(strTempF);
  // Use WiFiClientSecure class to create TLS connection
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    Serial.println("connection failed");
    return;
  }else{
    Serial.println("Connected to ThingWorx.");
  String url = "/Thingworx/Things/<YOUR_THING>/Properties/<YOUR_PROPERTY>";
  Serial.print("requesting URL: ");
  Serial.println(url);
  String strPUTReqVal = "{\"Temp\":\"" + strTempF + "\"}";
  Serial.print("PUT Value: ");
  Serial.println(strPUTReqVal);
  client.print(String("PUT ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "appKey: <YOUR_APP_KEY>" + "\r\n" +
               "x-thingworx-session: false" + "\r\n" +
               "Accept: application/json" + "\r\n" +
               "Connection: close" + "\r\n" +
               "Content-Type: application/json" + "\r\n" +
               "Content-Length: " + String(strPUTReqVal.length()) + "\r\n\r\n" +
               strPUTReqVal+ "\r\n\r\n");
  while (client.connected()) {
    String line = client.readStringUntil('\r');
    Serial.print(line);
  client.stop();
  // Run this every 5 seconds
  delay(5000);
9 REPLIES 9
Hi Adam Sanordontri,
Could you please try the following and see if it works?
Find the line char server[] = "ohimvo0g.studio-trial.thingworx.io"; in the code and update to char server[] = "ohimvo0g.studio-trial.thingworx.io:8443";
Save and upload the program to your ESP8266 board.
Go back to your HTU21D Thing properties section, click on the refresh properties button and see if the values are being updated constantly.
If this doesn't solve the issue you can revert to original settings.
I tried yo add :8443 for the server port .
I apologize for the inconvenience. Could you please revert the settings to the default, run the code on ESP8266 board and see if you can find any errors in the application log.
  #include "DHT.h"
  #include <Wire.h>
  #include <SPI.h>
  #include <Ethernet.h>
  //WiFi
  const char* password = "nslc3250";
char server[] = "13.114.212.97";
WiFiClient client;
//How many values you will be pushing to ThingWorx
#define propertyCount 2
char appKey[] = "4ae58966-c96d-4f07-ace6-43d9775347a3";
//Interval of time at which you want the properties values to be sent to TWX server
int timeBetweenRefresh = 5000;
//Initialize Properties Names and Values Arrays
char* propertyNames[] = {"Temp", "Humid"};
double propertyValues[propertyCount];
// last time you connected to the server, in milliseconds
unsigned long lastConnectionTime = 0;
// state of the connection last time through the main loop
boolean lastConnected = false;
//Initialize an DHT library object to read
void setup() {
  //shut down the SD Card pins
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.begin(9600);
  while (!Serial) {
   dht.begin();
  Serial.println("");
    delay(500);
    Serial.print(".");
  Serial.println("");
void loop() {
  propertyValues[0] = dht.readTemperature();
  propertyValues[1] = dht.readHumidity();
  // wait the established interval of time before
  // reading values from the sensor
  // and sending them to the TWX server again
  // delay(timeBetweenRefresh);
  if (millis() - lastConnectionTime > timeBetweenRefresh) {
    updateValues(propertyValues, client, server, appKey, thingName, serviceName, propertyNames);
void updateValues(double values[] , WiFiClient &client, char server[], char appKey[], char thingName[], char serviceName[], char* sensorNames[])
  //build the String with the data that you will send
  char data[80];
  strcpy(data, "?appKey=");
  strcat(data, appKey);
  strcat(data, "&method=post&x-thingworx-session=true");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print(data);
    client.print("<");
    for (int idx = 0; idx < propertyCount; idx++)
      client.print("&");
      client.print(propertyNames[idx]);
      client.print("=");
      client.print(propertyValues[idx]);
    client.print(">");
    client.println();
     client.stop();
    lastConnectionTime = millis();
    Serial.print(data);
    Serial.print("<");
      Serial.print("&");
      Serial.print(propertyNames[idx]);
      Serial.print("=");
      Serial.print(propertyValues[idx]);
    Serial.print(">");
    Serial.println();
  else {
    client.stop();
I used 30 days Thingwork trial sever  for testing because It use port No.80 to conect.
I´d appreciate if anyone can help me or give the example code for esp8266, thanks.
<YOUR_WIFI_SSID>
<YOUR_THING>
<YOUR_PROPERTY>
<YOUR_APP_KEY>
WiFiClient client;
void setup() {
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
  sensors.begin();
void loop() {
    return;
  }else{
    Serial.print(line);
  client.stop();
  delay(5000);
Thetowen
6-Contributor
(To:bmehringer)
Trying to get bmehringer code to work. I'm connecting to the Network but can't get it to update my values. I have created a generic thing called Thing_1 and in properties I've called it Temp and set the base type to Number and the Data change type to Value but it's not updating the value. Any ideas this is the print out?
PP-1803082301ME.Devportal.Ptc.Io
requesting URL: /Thingworx/Things/Thing_1/Properties/Temp
PUT Value: {"Temp":"111.00"}
PUT /Thingworx/Things/Thing_1/Properties/Temp HTTP/1.1
Host: PP-1803082301ME.Devportal.Ptc.Io
appKey: 91ff6af0-88fa-43b5-a44d-a0a498918xxx
Connection: close
Content-Length: 17
{"Temp":"111.00"}
Its Worked.
Thank you!
I have same problem here have you reach to any solution for this problem ?
why it couldn't reach server !!
bmehringer
(To:Ahmed189)
I had troubles getting my ESP8266 to connect until I started using the IP address instead of the server name.  I am no where near a network person, so I have no idea why the IP worked and the server name did not.
