Webframe not loading cross frame content
TanmeyTWX
I want to load some other application webpage into a Mashup and used Webframe widget for the same.But whenever I try to load mashup,getting below error.
“Refused to frame 'https://myWebsite/dashboards' because an ancestor violates the following Content Security Policy directive: "frame-ancestors 'self'".
As per the suggestion (Display Mashups from external Browser - PTC Community)
uncommented the filter in tomcat web.xml and now getting new error as shown below.
"Refused to display 'https://myWebsite/dashboards' in a frame because it set 'X-Frame-Options' to 'deny'.
Specs: Thingworx 8.5.4 Chrome Browser
4 REPLIES 4
Hello @TanmeyTWX ,
Have you reviewed the following article that may help https://www.ptc.com/en/support/article/CS264120
Hope it helps,
@Ciprian-Traian
Yes, I tried this but no luck.
slangley
23-Emerald II
(To:TanmeyTWX)
Hi @TanmeyTWX.
Please take a look at this article.  If you're still unable to get it to work, please provide the logs so we take a closer look.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @TanmeyTWX.
If the previous post provided the assistance you needed, please mark it as the Accepted Solution for the benefit of others with the same problem.
--Sharon
