The message you are trying to access is permanently deleted.
Yes it is not enough.
Could you find the info about the possible values for the "fillOption"?
If you look at the service itself you can see that is has the dropdown option for "None" and "Previous". As described in the documentation, the default is the "Previous" option which will use the last value received for a property to fill in gaps in between recorded timestamps/rows. The option "None" will leave the value for the specific property empty.
