Kindly what is the name of widget used in the screen which I attached in this post.
Hello.
This appears to be a custom variant of the ThingWorx Progress Gauge. I'm not familiar with the exact nature of this customization. Possibly something for Manufacturing or Navigate applications? This is likely something customized specifically for your use case(s), so Technical Support is limited or unavailable for it.
Thank you,
-- Craig A.
Hello.
Thank you,
-- Craig A.
