What's the difference between GetCurrentLicenseInfo & GetDaysRemainingInLicense wrt to license days?
ranjank
Hi Team,
Why there is difference in results of below two services of LicensingSubsystem?
1)
GetCurrentLicenseInfo- This service is giving me the no of days for one of my instance as 15.
2)
GetDaysRemainingInLicense- This service is giving me the no of days for same instance as -14 (minus 14)
What is the difference between these two results and what is the significance of negative value of second service?
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:ranjank)
Hi @ranjank.
This may have been a bug in that release.  In my testing under 9.0, it works as expected.
Note that ThingWorx 8.3 is no longer supported.  It would be a good idea to schedule an upgrade of your environments.  Please refer to the Product Release Calendar for product support end dates for each release.
--Sharon
5 REPLIES 5
PaiChung
22-Sapphire I
(To:ranjank)
GetCurrentLicenseInfo should give you all the different features you are enabled for by your license and the expiration if known.
Not sure how GetDaysRemainingInLicense is giving you a different number though, that is rather strange.
Should give you the same number or Null/NA
slangley
23-Emerald II
(To:PaiChung)
Hi @ranjank.
I agree with Pai's response.
What version of ThingWorx are you running?
--Sharon
ranjank
(To:slangley)
@slangley @PaiChung
The ThingWorx version is 8.3.4.
Also have enclosed the scheenshot for GetDaysRemainingInLicense service result.
slangley
23-Emerald II
(To:ranjank)
Hi @ranjank.
--Sharon
slangley
23-Emerald II
(To:ranjank)
Hi @ranjank.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
