Do anyone now what is the differences between the Database thing template and the MSSqlServer thing template?
BR / Simon
Okay then the Database thing is the default/main thing template to use. I am guessing that the MSSqlServer thing template is a custom deployed to our environment via a extension. Thank you for the help.
We are using Thingworx 9.3.9.
Here, only "Database" thing template available.
I hope, both are same.
Hi @STullberg.
You'll want to use the Database thing template. It contains the logic for connecting to a JDBC database including SQL Server. There is no MSSqlServer thing template. I think you have it confused with the SQLThing thing template.
Regards.
--Sharon
