I have written a sql query where when i execute I am getting the result in output window but when i bind that value to led it's showing nothing.
I have followed
But there is no use can anyone please help me in this ?
Regards
Bhargav
I suppose you have a mashup with the led widget, please click on View Mashup.
Click on Show/Hide Debug Info and enable Bindings. Can you identify the binding between the led and result of query?
Raluca Edu
Hi ,
This is the log it's showing
Raluca Edu
Raluca Edu
I can see there is error with binding the led widget, I cannot figure it out only from the above errors.
Please check the binding for led and also access rights to run a specific service (you are using admin or non-admin user?)
Please give a little bit more of details on how you get the info from database, what service/code you are using, etc.
Thank you,
Raluca Edu
