Hi ,
This is the log it's showing
16:23:04 INFO - ThingWorx Mashup Runtime vundefined
16:23:07 WARN - trying to set a parameter that is not defined: "forceClose". Ignoring it
16:23:11 WARN - trying to set a parameter that is not defined: "features". Ignoring it
16:23:13 ERROR - Runtime exception handling data update for binding {"Id":"1d295e6e-57d8-41e5-9f75-ee119b59d702","SourceArea":"Data","SourceSection":"Things_Database","SourceId":"Container_Dashboard_values","SourceDetails":"AllData","TargetArea":"UI","TargetSection":"","TargetId":"leddisplay-9","PropertyMaps":[{"SourceProperty":"result","SourcePropertyType":"Field","SourcePropertyBaseType":"NUMBER","TargetProperty":"Data","TargetPropertyType":"property","TargetPropertyBaseType":"NUMBER"}],"isBoundToSelectedRows":false} Exception: Cannot read property '0' of undefined
16:23:13 ERROR - Error in invoking service Things_Database, Container_Dashboard_values, Things, Database, Services, Container_Dashboard_values. Error from the server: "Unable to Invoke Service Container_Dashboard_values on Database : Execute Update failed: org.postgresql.util.PSQLException: A result was returned when none was expected."
16:23:13 ERROR - Runtime exception handling data update for binding {"Id":"050e949e-f259-4f9c-a307-4f7610be2bf4","SourceArea":"Data","SourceSection":"Things_Database","SourceId":"openstreet_map_test","SourceDetails":"AllData","TargetArea":"UI","TargetSection":"","TargetId":"dhxgrid-13","PropertyMaps":[{"SourceProperty":"","SourcePropertyType":"InfoTable","SourcePropertyBaseType":"INFOTABLE","TargetProperty":"Data","TargetPropertyType":"property","TargetPropertyBaseType":"INFOTABLE"}],"isBoundToSelectedRows":false} Exception: Cannot read property 'length' of undefined
16:23:13 ERROR - Error in invoking service Things_Database, openstreet_map_test, Things, Database, Services, openstreet_map_test. Error from the server: "Error executing service. Message ::Unable To Convert From org.mozilla.javascript.UniqueTag to INFOTABLE - See Script Error Log for more details."
16:23:13 ERROR - Error in invoking service Things_Database, upload_data, Things, Database, Services, upload_data. Error from the server: "Unable to Invoke Service upload_data on Database : Execute Query failed: org.postgresql.util.PSQLException: ERROR: syntax error at or near "$1" Position: 8"
@raluca_edu wrote:
I suppose you have a mashup with the led widget, please click on View Mashup.
Click on Show/Hide Debug Info and enable Bindings. Can you identify the binding between the led and result of query?
Raluca Edu
Raluca Edu
