Dear ThingWorx support team,
I want install ThingWorx a docker container as documented in support.ptc.com/WCMS/files/173161/en/ThingWorxDockerInstaller.pdf
. However I cannot find the download link in my eSupport page.
Would you be so kind to help me? Thank you.
Cheers, Christian
The link has my authentication session in the middle, so probably that's why you can't access it.
Just visit the TWX download page follow your route, if you can find the download page, then you can find the docker installation package. If you can't get to the download links, then probably you need to check your license status
Hi Cherlam,
You should visit the site https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX , (Regular download link you used to find TWX installer) Software Downloads - Order or Download Software Updates
The Docker installer can be found in almost every version after 8.0 release
Dear zyuan1,
Thank you for the fast response. Unfortunately if I open the link, it shows no download link at all(See attached screenshot).
Could it be that my license subscription already expired?
Cheers, Christian
OK. That's the root cause. Thank you.
