Hi, i look for ThingWorx connect method
i found and built KEPServer and REST[only POST, i don't know another method]
now i'm try connect Thingworx use EMS with C SDK
but link in community wasn't opened
so if you have some example or guide or tutorial files[video, pdf, etc..], please share them with me
thanks
Hi Seonho, sorry it's bit unclear are you using WSEMS or you want to use ThingWorx C SDK? These are two different connectivity methedologies/technologies even though WSEMS likely draw it's base from C SDK. If you are looking for samples you can access them here
1. Connect a Raspberry Pi to ThingWorx using the Edge Micro Server (EMS)
Please feel free to correct me if this isn't what you are looking for.
What do you use to compile the C SDK?
Is it ok to use visual studio?
opened main.c in SteamSensor, didn't debug
cause didn't find twExt.h
how can i set a header path?
thanks
seonho Cha: Thanks, I see you have opened a support case with us and our team will review it to provide you further assistance.
-Durgesh
