Where can i get Example of EMS using C SDK?
CHASEONHO
18-Opal
Hi, i look for ThingWorx connect method
i found and built KEPServer and REST[only POST, i don't know another method]
now i'm try connect Thingworx use EMS with C SDK
but link in community wasn't opened
so if you have some example or guide or tutorial files[video, pdf, etc..], please share them with me
thanks
supandey
(To:CHASEONHO)
Hi Seonho, sorry it's bit unclear are you using WSEMS or you want to use ThingWorx C SDK? These are two different connectivity methedologies/technologies even though WSEMS likely draw it's base from C SDK. If you are looking for samples you can access them here
1. Connect a Raspberry Pi to ThingWorx using the Edge Micro Server (EMS)
2. C SDK Reference Guide
Please feel free to correct me if this isn't what you are looking for.
supandey
(To:CHASEONHO)
What do you use to compile the C SDK?
Is it ok to use visual studio?
dupatel
(To:CHASEONHO)
seonho Cha​: You can use Visual Studio for C SDK project/solutions.
-Durgesh
opened main.c in SteamSensor, didn't debug
cause didn't find twExt.h
how can i set a header path?
thanks
dupatel
(To:CHASEONHO)
seonho Cha​: Thanks, I see you have opened a support case with us and our team will review it to provide you further assistance.
-Durgesh
