Where is Thingworx Entities Stored?
NBHD207
Hello All,
I'm using Thingworx Flatform 8.3 with postgresql database,
I have a question where will the created entities be stored? in the folder or in the database. For example, with the Mashup Entity, I checked the database and found only the columns for configuring the mashup parameter, not the code to build the mashup.
Can anybody help me answer this question?
Thanks and Best Regards.
NBHD.
Everything it's stored on the Database, the only things which aren't stored are FileRepository content and at starting on some versions the password/appkeys information.
@NBHD207 I just wanted to follow up with you to see if the previous response was helpful for your question.
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
NBHD207
(To:CarlesColl)
Hi CarlesColl,
Very grateful for your help
NBHD207.
