Hi all,
I am wondering if there is a specific reason that Master cannot be bound in thingworx mashup builder. I have a mashup in one project that I want to use the same master on as all of our other mashups but the master is located within our main project with stuff to be commonly used among all projects. This creates a dependency issue preventing pushing between projects and I am not sure if there is really a good way around this, but if I could just bind a string like "KT.MasterMashup" to the Master parameter then I could solve that dependency.
Hi @JK_10744682,
I guess the Product Manager just doesn't expect users to change the master dynamically "on the fly".
You can post your ideas on https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas
However, I don't quite get the dependency issue you mentioned, you may want to explain more about your use case and how bindable master can help when posting your enhancement idea.
Best,
Hi @JK_10744682,
Best,
