Stacked Combochart
I am using ThingWorx Platform Release 9.5 and DatecodeF000
I would have a "general" question about the Combo Chart widget. Unfortunately I did not find any examples on the internet. I see that with a combo chart I can have multiple y-Axes which is great. Now I saw that you even have the possibility to have it stacked. Which would mean in my opinion I have multiple y-Axes therefore multiple lines but they all have there own space. Not all together in one graph but stacked as I would need to have it. Now I played a bit with the widget and tried out what I can do but unfortunately nothing happens when I choose the Stacked option. I mean there are a lot more parameters then that i tried to correctly fill but in the end result nothing happened. So I would kindly ask you if there is a better description on how to obtain this stacked result that i definetly need or is it maybe a bug that this is not working?
