Wildcard in SQL query with input param
ague
I need to make a SQL query in Thingworx. The query should read (if I were creating it directly):
SELECT * FROM MyDB.MyTable where Name like '%Name_Input%'
Another PTC forum post had recommended this as a possible solution:
SELECT * FROM MyDB.MyTable where Name like '%' || [[Name_Input]] || '%'
But this query (above) does not work. The post was from the year 2014 and I'm currently using 8.4.1, so I'm guessing that's the issue.....
Solutions anyone?
13 REPLIES 13
posipova
20-Turquoise
(To:ague)
This could have been changed due to the changed security policies. I will verify and get back to you/this thread with an update.
posipova
20-Turquoise
(To:posipova)
This was part of security updates, works to spec.
ague
(To:posipova)
So, when you say, 'works to spec', are you saying that this SQL query should in fact work?
posipova
20-Turquoise
(To:ague)
Wildcard should not work, sql queries should work.
ague
(To:posipova)
So, how can I execute a SQL query that needs to take in a variable? What's the work-around for this?
posipova
20-Turquoise
(To:ague)
ague
(To:posipova)
It tells me how to use a variable from a user (fine, I know how to do that), but it doesn't mention being able to user wildcards WITH the variable.
I know I can use wildcards WITHOUT a variable.
posipova
20-Turquoise
(To:ague)
I don't think we support wildcard without a variable/security patches.
ague
(To:posipova)
Please elaborate on what 'variable patches' are.
posipova
20-Turquoise
(To:ague)
I apologize for wording that poorly. "/" Should be read as "(security patches)".
ague
(To:posipova)
What security patches are required then? What updates do I need?
posipova
20-Turquoise
(To:ague)
It's already part of the newer build that's why the suggestion from older (2014) thread did not work. I'll place an improvement request on your behalf.
JT_OU812
(To:ague)
I had the same issue, here's what I found to work, this works in 9.4.1:
SELECT * FROM MyDB.MyTable where field_values LIKE '%'+[[source]]+'%'
