I need to make a SQL query in Thingworx. The query should read (if I were creating it directly):
SELECT * FROM MyDB.MyTable where Name like '%Name_Input%'
Another PTC forum post had recommended this as a possible solution:
SELECT * FROM MyDB.MyTable where Name like '%' || [[Name_Input]] || '%'
But this query (above) does not work. The post was from the year 2014 and I'm currently using 8.4.1, so I'm guessing that's the issue.....
Solutions anyone?
This could have been changed due to the changed security policies. I will verify and get back to you/this thread with an update.
This was part of security updates, works to spec.
So, when you say, 'works to spec', are you saying that this SQL query should in fact work?
Wildcard should not work, sql queries should work.
So, how can I execute a SQL query that needs to take in a variable? What's the work-around for this?
It tells me how to use a variable from a user (fine, I know how to do that), but it doesn't mention being able to user wildcards WITH the variable.
I know I can use wildcards WITHOUT a variable.
I don't think we support wildcard without a variable/security patches.
Please elaborate on what 'variable patches' are.
What security patches are required then? What updates do I need?
I had the same issue, here's what I found to work, this works in 9.4.1:
SELECT * FROM MyDB.MyTable where field_values LIKE '%'+[[source]]+'%'
