What is the use of the Workflow subsystem? while connecting workflow subsystem giving this error message
Hi @VS_10112707 ,
Workflow subsystem is the part of ThingWorx Flow, which can be downloaded from support portal and installed on top of the ThingWorx Foundation.
Check the following link: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/CreatingNewWorkflow.html#wwID0E1HZIB
Revert back if you have any queries.
Bhawna
is possible to connect in trial version
Hi @VS_10112707 ,
You may download Twx Flow from the given link:
https://www.ptc.com/en/support
Pls refer the attached screenshot.
Follow this link for ThingWorx Flow installation: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/ThingWorxFlow.html#
