Workflow Sub system
VS_10112707
Workflow Sub system
What is the use of the Workflow subsystem? while connecting workflow subsystem giving this error message
4 REPLIES 4
Hi @VS_10112707 ,
Workflow subsystem is the part of ThingWorx Flow, which can be downloaded from support portal and installed on top of the ThingWorx Foundation.
Check the following link: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/CreatingNewWorkflow.html#wwID0E1HZIB
Revert back if you have any queries.
Regards
Bhawna
is possible to connect in trial version
It means have to download any extension and is it possible in trial version?
And can you please share links to download any extension
Hi @VS_10112707 ,
You may download Twx Flow from the given link:
https://www.ptc.com/en/support
Pls refer the attached screenshot.
Follow this link for ThingWorx Flow installation: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Integration_Orchestration/ThingWorxFlow.html#
