Write CSV to local folder
Lakshmit
9-Granite
Hi All,
Using CSV parser extension service WriteCSVFile am storing CSV file in SystemRepository. But my requirement is to save the file to local folder. Is there a way we can achieve this.
Thanks in Advance.
Regards
Lakshmi.
drichter
(To:Lakshmit)
This will not work. All Services run on server side. There have no access to your local filesystem.
6 REPLIES 6
drichter
(To:Lakshmit)
First you create the file in a FileRepository and then you can use the GetFileListingWithLinks-Service of this FileRepository to download the file.
bot1q
(To:Lakshmit)
if you want to have an Export in your Mashup.
Use Data Export widget. This will save the CSV in your default browser location (or ask) when you press it.
Lakshmit
9-Granite
(To:bot1q)
Thank you for reply, but I want to avoid extra click for data export. Instead storing in Repository I was trying to save in local folder using below code.
var params = {
path: "/Data.csv" /* STRING */,
data: result1 /* INFOTABLE */,
 fileRepository: ??? --- Is there a way we can store in local folder?
// fileRepository: "SystemRepository" /* THINGNAME */,
withHeader: true /* BOOLEAN */
// no return
Resources["CSVParserFunctions"].WriteCSVFile(params);
Here WriteCSVFile function stores CSV in fileRepository mentioned in params(Here it is SystemRepository).
drichter
(To:Lakshmit)
Sure, Then will try with FileRepository logic. Thank you for your support.
bot1q
(To:Lakshmit)
If the export is somehow triggert from any User Input. Then just add a "automatic export" handler in the Date Export Widget and you will avoid an extra click.
