XML LoadXML
BryanK
XML LoadXML
Hi All,
I have a Site that I am reading xml data from. The problem that I have is using the loadXML script.
if I run postman I get the following.
<?xml version="1.0" encoding="UTF-8"?>
<Rates>
    <Rate Symbol="EURUSD">
        <Bid>1.07607</Bid>
        <Ask>1.07632</Ask>
        <High>1.07633</High>
        <Low>1.07311</Low>
        <Direction>0</Direction>
        <Last>22:40:33</Last>
    </Rate>
</Rates>
I have created a service that I want to use that will pull that information. as shown below.
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /*'Rates' /* JSON */,
url: http://thisisthewebsiteurl /* STRING */,
timeout: '60' /* NUMBER */,
// result: XML
var xml_file = Resources["ContentLoaderFunctions"].LoadXML(params);
var params = {
fieldMap: undefined /* INFOTABLE */,
xml: xml_file /* XML */,
rowPath: 'Rate'  /* STRING */,
dataShape: 'forex_xml' /* DATASHAPENAME */
// result: INFOTABLE
var result= Resources["UniversalConverterFunctions"].ConvertXML(params);
this gives me the following.
where symbol is missing.
If I take rowPath: 'Rate'  out I get nothing.
The issue I believe is that the <rate Symbol=xxxx> is embedded.
Any idea how I can handle that seeing as I cant do anything with the xml file I'm reading.
ptc-6292103
(To:BryanK)
Try adding this after the line 'var xml_file = ...'
for(var index = 0; index < xml_file.Rate.length(); index++)
    xml_file.Rate[index].Symbol = xml_file.Rate[index].@Symbol.toString();
ptc-6292103
(To:BryanK)
