bacnet to thingworx
sasodi
bacnet to thingworx
I am looking to connect bacnet to thingworx for monitoring a HVAC system. Can anyone provide a partner that can help with that?
ntk-2
(To:sasodi)
I too have similar requirements, but does n't see any one answering from ThingWorx.
jcanosa
(To:ntk-2)
Please take a look at Cimetrics - a ThingWorx partner that is probably the largest provider of BACnet SW in the world.
ndionne
7-Bedrock
(To:sasodi)
You also have the option of using an OPC server such as Kepware or Matricon to connect to your Bacnet device and then use the OPCDA edge connector to bring your data into the platform. It adds another layer, but is an option. If you already are gathering the data in an OPC server the edge server would be the way to go.
