cannot add rows to InfoTable session variable
KK_9150368
I have an infotable session variable called  testsessvar,  it is defined with a datashape (containing 2 text fields:  Doc_Name,  Doc_URL)
on the server side I have a service defined as follows
input  newinfotable_entry     (using same dateshape as the one the session variable uses)
tmp = Resources["CurrentSessionInfo"].GetGlobalSessionValues().getRow(0).testsessvar;
tmp.AddRow(newinfotable_entry);
result = tmp;
the output of this service is connected with the session variable in the mashup (so the update of the session variable is being done on the client side,  I have also tried to update it in the script with same result)
The idea is to be able to continually add rows to the infotable session variable
unfortunately the only thing being added is empty objects (the below image shows what gets returned from
the above service)
This second image shows the input value of newinfotable_entry
Hi @KK_9150368,
I have attached some example entities that shows adding rows to a session variable.  I am not exactly sure why your example is not working but in mine I passed in the info table session variable to my service to add rows.
If you are updating session variables via the session tab in a mashup ( client side ) it is best to pass this variable into your target service instead of using: "Resources["CurrentSessionInfo"].GetGlobalSessionValues().getRow(0).testsessvar".  The resources gets session variables server side.
Travis
6 REPLIES 6
KK_9150368
(To:KK_9150368)
BTW,  the 2 versions of TWX if have tried this on are:   9.2.0-b30  and 9.1.0-b10877
M4RC
(To:KK_9150368)
I am not a professional, but when adding values, I assign the row-values individually.
Like this:
tmp.AddRow({
      Doc_Name: newinfotable_entry.Doc_Name,
      Doc_URL: newinfotable_entry.Doc_URL
I hope this helps
Best regards
KK_9150368
(To:M4RC)
I actually tried that also to no avail
Hi @KK_9150368,
Travis
KK_9150368
(To:TravisPickett)
Travis,
     Thanks for the info.  I decided to use a data table instead.   I will keep this for future reference
slangley
(To:KK_9150368)
Hi @KK_9150368.
It sounds like your question was answered to your satisfaction.  If so, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
