18-Opal
October 20, 2021
JSON in Grid Widget
  • October 20, 2021
  • 2327 views
When Trying to display the threshold parameter in the Grid, it is showing [object][object], How values can be displayed.
Issue with JSON Variable Display on Grid:
@c_lowy @slangley @paic
Shashi
Best answer by pshashipreetham
Hi @PaiChung ,
Thanks for the quick reply, got it, should it be done from service or can it be changed in the GRID Configurations ?
followed a article here, but this didn't work.
Shashi Preetham.
22-Sapphire I
October 20, 2021
unfortunately the grid won't display json objects, you could convert it to string to display.
pshashipreetham18-OpalAuthorAnswer
18-Opal
October 20, 2021
Hi @PaiChung ,
Shashi Preetham.
Community Manager
October 28, 2021
Hi @pshashipreetham.
We tested under ThingWorx 9.2.3 and it worked fine.  Can you provide your code?
Regards.
--Sharon
