I want to do drop down layer by layer. for example. if I choose Production Volume and choose milk, next layer cannot show “Mozzarella” in the drop down.
You would create query services for each selection and then bind those to list/dropdown widgets.
after selection in one list, re-fire the services as necessary to repopulate them
Can I ask how much of the Thingworx training have you finished so far and what have you done so far in creating services and mashups?
I'd like to have a baseline before I start explaining the steps.
Actually, I just finished www.developer.thingworx.com tutorial, basic one only. services and mashup.
So I really need coding in details. logic I understand, but I don't know how to do in thingworx.
Great so you know how to create services and how to display returned information in a mashup.
Services can be set up with input parameters.
You'll have a service per each list/drop down box
based on 'selected row' of the source to a box, you now have the input parameters for the next service
based on 'selected row' changed you will trigger that next service which will bring back the data for the next drop down
Yes. Let me show you my logic.
First, I created one datashape, which included first layer name(string type) and next layer(infotable type). and I create Datatable which used this datashape.
but my question is after I want to input data in the datadatable, only first layer name can put data, infotable cannot put data.
It is a bit difficult to answer your question since it is hard to understand exactly what you have and how you are trying to do it
DataTables have services to store data (as well as retrieve and query) those you'd leverage to interact with the datatable.
you can see from my file inserted. I cannot edit infotable data in the datatable.
I apologize for not having the time to download and import your entities.
Sounds like very likely you are trying to do something that the widgets do not support.
So you may have to provide a different construct to allow the editing of that table inside your table.
For example use the selected row capability to display that table in yet another grid.
