hi,
I can't seem to enter numbers using the numeric keypad in the dateTime picker widget ,
Is there a way to allow insertion with the numeric keypad on this widget?
I'm pretty sure this is a known issue on some systems; if the numpad doesn't work (after checking num lock/scroll lock), you just have to use the number row.
good to know,
thanks!
