error while installing thingworx trial
nairobi22
Hi dears,
while I tried to install ThingWorx Trial, following Error occurred (attached).
Hope, you can help me with this.
Greets,
1 ACCEPTED SOLUTION
nairobi22
(To:vxavier)
I'm not sure :D
Befor I tried again I deleted every installed ThingWorx Data and the Docker VM Machine.
I think, there was also a storage problem.
5 REPLIES 5
vxavier
(To:nairobi22)
What is the OS? Are you running in docker?
nairobi22
(To:vxavier)
Windows 7 Enterprise, running in docker, yes
nairobi22
(To:nairobi22)
vxavier
(To:nairobi22)
Can you share the solution?
This way if anyone has the same problem it could help them.
Vinicius Xavier.
nairobi22
(To:vxavier)
I'm not sure :D
