export vs export to source control
ashaban
11-Garnet
Hi All,
What is the difference between the export of a single entity to export "to source control"? Is there any difference other than the indentation?
When is it recommended to use the "regular" export?
Avihu.
posipova
20-Turquoise
(To:ashaban)
Source control -- Exports ThingWorx entities by collection, model tags, project, start and end dates. The specified entities can be directed to a FileRepository or SourceControlRepositorything. When entities are exported, a file structure is created at the destination that resembles the way a source control system manages its artifacts. If you want to move or copy exported files to another location, you can export the file structure as a zip file.
Single file export -- Can export a single entity to a selected local destination (synchronous).
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FGetting_Started%2FImportingandExportinginThingWorx%2FImportingandExportingDataEntitiesandExtensions.html
posipova
20-Turquoise
(To:ashaban)
