fix Radio Button and Generic Radio button not selecting default
SOLVED
Highlighted
Newbie
I'm using a radio button to allow the user to choose between entering the coordinates in directly or an address which will be changed into coordinates. But the radio button does not select the default state. Below is my state definition, I have tried using both a radio button and a generic radio button.
1 ACCEPTED SOLUTION
Re: fix Radio Button and Generic Radio button not selecting default
actually, should be in the latest patch of 6.5
9 REPLIES 9
What is your Thingworx version?
6.0
I'm attaching my entities from Thingworx 7.3.3 to demonstrate a working radiobutton (mashup, 1 state, 2 styles attached):
It was fixed in 6.5
so default has zero functionality on radio buttons before 6.0? I can do a work around then.
Okay, we'll be able to use it once we upgrade then I guess.
Polina Osipova​​, is there a patch for version 7.4.0? I'm experiencing the same issue. Upon mash-up loaded event, a button corresponding to the default state is active, but the SelectedText output of the widget is nothing, "". Thanks.
Might be a regression, let me test this.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
