fix Radio Button and Generic Radio button not selecting default
cjones-5
1-Newbie
I'm using a radio button to allow the user to choose between entering the coordinates in directly or an address which will be changed into coordinates. But the radio button does not select the default state. Below is my state definition, I have tried using both a radio button and a generic radio button.
posipova
20-Turquoise
(To:cjones-5)
actually, should be in the latest patch of 6.5
9 REPLIES 9
posipova
20-Turquoise
(To:cjones-5)
What is your Thingworx version?
6.0
posipova
20-Turquoise
(To:cjones-5)
It was fixed in 6.5
posipova
20-Turquoise
(To:posipova)
I'm attaching my entities from Thingworx 7.3.3 to demonstrate a working radiobutton (mashup, 1 state, 2 styles attached):
so default has zero functionality on radio buttons before 6.0? I can do a work around then.
posipova
20-Turquoise
(To:cjones-5)
Okay, we'll be able to use it once we upgrade then I guess.
Polina Osipova​​, is there a patch for version 7.4.0? I'm experiencing the same issue. Upon mash-up loaded event, a button corresponding to the default state is active, but the SelectedText output of the widget is nothing, "". Thanks.
posipova
20-Turquoise
(To:Michail)
Might be a regression, let me test this.
