get StreamEntryId from a stream
dbologna1
Hi All,
I have problem to get the StreamEntryId  of last record inserted into a stream. I'm using AddStreamEntry to add the new record.
Following the list of steps :
1) search information
2) add the information to the stream using the AddStreamEntry
3) If I use QueryStreamEntriesWithData with last timestamp used to add the record (#2) --> no data found
4) If I use GetStreamEntries (oldestfirst=false) an StreamEntryId is returned  but it is not the last inserted (not the one I need)
How can I get the StreamEntryId of the last added record ?
These instructions are all part of the same service inside a loop, and the StreamEntryId is needed to refer the correct record.
BR
Dimitri
nbansal
(To:dbologna1)
Hello Dimitri,
You can try using below piece of code with OldestFirst = false and result as NUMBER:-
// result: INFOTABLE
var result1 = Things["NameOfStream"].GetStreamEntriesWithData(params);
//id is the column name to be fetched
var result= result1.rows[0].id;
Hope this helps!
Nidhi
Hello Dimitri,
AddStreamEntry it's an async process, writes are put on a buffer. Then if you query right on the same script for the added entry you will never find it.
Best Regards,
Carles.
