get current Datatable row count
xiaoqw
when I write services behind current datatable, I need to get number of rows of this datatable.
this is my code I used:
var result = me.getRowCount();
the output should be integer.
but after I run this code, here is output error says: cannnot find functon getRowCount in object com.thingworx.datatables.
how to fix this problem?
Use this service instead:  GetDataTableEntryCount
3 REPLIES 3
The getRowCount() service is only used in infotable, so it returns the size of a infotable chunk, not the Datatable entity.
xiaoqw
(To:zyuan1)
ok. thank you. it helps
