Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
2020-14-01 12:32:12.362 [ClientProcessor-3] ERROR c.t.i.r.IntegrationEngine - Exchange process failed with exception thrown : Your route exchange has failed. Resource Error [sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target] java.lang.RuntimeException: Your route exchange has failed. Resource Error [sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target] at com.twx.integration.route.exceptions.ExceptionHelper.convertToRuntimeException(ExceptionHelper.java:77) at com.twx.integration.route.IntegrationEngine.dispatchRoute(IntegrationEngine.java:159) at com.twx.integration.client.things.IntegrationRuntimeServer.Invoke(IntegrationRuntimeServer.java:72) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:261) at com.thingworx.communications.client.things.VirtualThing.invokeService(VirtualThing.java:1120) at com.thingworx.communications.client.things.VirtualThing.handleServiceRequest(VirtualThing.java:1028) at com.thingworx.communications.client.ConnectedThingClient.handleRequest(ConnectedThingClient.java:315) at com.thingworx.communications.client.processor.ClientProcessorTask.run(ClientProcessorTask.java:55) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
If the response provided by @raluca_edu answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
