You may want to take a look at this thread Google Maps no longer displaying (Error - 'Oops! Something went wrong')
It may be missing Google API Key in metadata.xml file.
Hi Sushant & Varathan, thank you very much, from the browser developer console, it seems the Google API key problem, I will find how to put Google API key in metadata.xml.
How could I extract metadata.xml and modify it ? Extension just could be imported or viewed from composer.
It's right to download google widget extension from makerplace, and modify metadata.xml, and import extension?
Hi Sandra, yes it OK to do that to update the key. In fact you can refer to this article guiding you on how to update the key in the metadata.xml API Keys and the Google Map Widget in ThingWorx
Hope this'd help.
Hi Sushant, thank you for your help, google map can be viewed normally.
Glad it helped
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
