Is it possible to copy entire row from grid widget or advanced grid? copy paste to excel.
Do you mean select with a mouse and copy/paste (ctrl-c/v)? If so, then yes, you can do that with advanced grid widget.
This doesn't work for entire row, is there a property / setting i'm missing?
I've tried this in 8.4 with no extra settings other than the defaults.
Have you checked out the advanced grid?
i'm running 8.3.4.
See my config:
any other info?
In 8.4, I am able to select and copy the entire row in grid advanced, with all of the default settings.
does it work for you for the standard grid? I cannot work out how to use the advanced grid, It doesnt do anything when I try to sort (clicking the header)
