We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
is there any way we can connect thingworx to raspberrypi rather than using edge microserver.
help out in an easy way to connect raspberrypi to thingworx, the steps given in this link is not helpful https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/install-ems
Make it easy, as i am struck with step 5.
help me as soon as possible
As far as I know there is no other way to connect Thingworx to the Raspberry Pi.
However I can explain step 5 to you:
Step 5 is used to verify that the unzip operation on the zip file was successful.
The command you're asked to execute "ls -l" lists the files and directories of the current path you're in, the "-l" switch is used to show further details, size, modified date and time, permissions and owners.
In the list provided you should find the folder microserver which indicates a successful unzip operation.
In case your list is too large and not conveniently readable you can pipe the output of the command to a file, that you can then open in a text editor. This can be done like so:
"ls -l >> list.txt" and will create a file called list.txt with the content of the commands output.
In Step 6 you [c]hange [d]irectory by running cd microserver which directs your current shells path to the microserver directory.
Let me know if you still have questions regarding the steps.
Pascal
Hi @ziondivya.
If the response provided by @pgrodowski has answered your questions, please mark it as the Accepted Solution, for the benefit of others who may have the same questions.
--Sharon
hello all, could you help me in rectifying this error, when launching ems server
here is the config.json file code for connecting ems
"ws_servers": [{
"host": "192.168.43.214",
"port": 80
"http_server": {
"host": "192.168.43.232",
"port": 8080
"appKey": "d59527d8-4161-4187-a15a-5120fdd65c35",
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"allow_self_signed": true
"ws_connection": {
"encryption": "none",
"verbose": true,
"msg_timeout": 1000
