based on my requirement, I need to use LabelAngle. but it not works. May I know what wrong with my input in LabelAngle?
Hi @xiaoqw.
The value you entered for label angle is working under ThingWorx 8.4/Chart widget extension 3.0.3. However, we're not understanding the value you entered for angle. We would expect it to be something like 90 or 45 degrees. Could you try this to see if you get different results?
--Sharon
Hi @xiaoqw.
--Sharon
Hi @xiaoqw.
Just checking to see if the previous suggestion helped to solve your issue. If so, please mark it as the Accepted Solution for the benefit of others on the community. If you found a different solution, please feel free to post it here and mark that as the Accepted Solution.
--Sharon
