Oct 29, 2019 6:25 PM UTC
API call with InfoTable input results in "Unable To Parse JSON Request"
I have a python script that's calling a ThingWorx Service. I'm calling a different service elsewhere in the script and it's working, but I'm not sure why this one isn't. The only difference is that this service has an InfoTable input.
Here's the relevant code.
propNames = {
 "dataShape": {
 "fieldDefinitions": {
 "name": {
 "name": "name",
 "baseType": "STRING"
 "description": {
 "name": "description",
 "rows": [{"name": "Stat_DisplaySpeed1"}]
params = {
 "maxItems": 500,
 "propertyNames": propNames,
 "startDate": startDate.replace(tzinfo=timezone.utc).isoformat(),
 "endDate": endDate.replace(tzinfo=timezone.utc).isoformat(),
 "query": ""
headers = {
 "appKey": PROD_KEY,
 "Accept": "application/json",
 "Content-Type": "application/json"
r = requests.post(url, params=params, headers=headers)
(startDate and endDate are defined elsewhere in the code)
This results in a status code of 406 with the body "Unable To Parse JSON Request"
Am I somehow forming "propertyNames" incorrectly? I'm confused about what's going on here.
mdszyAnswer
Oct 30, 2019 5:18 PM UTC
I get a different error "accessing data provider" when I send without any data.
But going the route of QueryNumberPropertyHistory is working.
Oct 30, 2019 2:33 PM UTC
Could you please share your TWX service code?
mdszy1-VisitorAuthor
Oct 30, 2019 2:34 PM UTC
This is calling the built in QueryNamedPropertyHistory service.
Oct 30, 2019 4:25 PM UTC
I have not done this from Python. So, I could be wrong. Probably you need to enclose propNames value in double quotes(beginning and end) and escape all other ones.
"{\"dataShape\":{\"fieldDefinitions\":{\"name\":{\"name\..........."
Oct 30, 2019 4:26 PM UTC
So you're saying propNames actually needs to be converted to a JSON string and passed along? Tried that, didn't work.
Oct 30, 2019 4:33 PM UTC
Execute QueryNamedPropertyHistory from composer and use Chrome Developer tools to get the request payload being used for the execution. You could then modify this to generate your call.
Oct 30, 2019 4:39 PM UTC
I have copy-pasted from Chrome's inspector and I still get the error.
18-Opal
Oct 30, 2019 5:05 PM UTC
Hello @mdszy ,
I would troubleshoot it as follows:
1. Try to call it without any parameters at all (empty JSON)
2. If it works, start adding parameters one by one in this order: maxItems, startDate / endDate (by the way, I think you might need them in milliseconds-since-epoch here, not ISO strings), and finally propertyNames
3. Alternatively, since you're querying only one property anyway, I would recommend using QueryStringPropertyHistory (or its analogue for Number, etc.), which doesn't require INFOTABLE parameter, but only a String
/ Constantine
