how to define other programming language or where to use in ThingWorx
Hariharasuthan
Hi Expert
how to use other programming language? or script? or possible to means where define or where use? in thingworx?
regarding my requirement
1.php application developed some module use into thingworx 9.3 version ,
2.html tage need for my application ,where use , and declare
3.i have java language use developed  some modules ,
please explain expert  , i am  thingworx  technology new one.
thanks With regards
Hariharasuthan
2 REPLIES 2
Hello @Hariharasuthan
I do not know of any ways to include modules from other languages into Thingworx. So for your #1, perhaps you could use the Web Frame widget to display your PHP application?
For #2 I am not sure I understand your requirements.
For #3 you can probably find what you need in this support article: PTC Article about creating custom widgets/extensions.
Hope this helps.
Jens
Hariharasuthan
(To:jensc)
Hi @jensc
  thingworx is not supporting for
1.pdf creator not working
2.html not supporting
3.animation with media Tage
 also another language
