how to display this chart using thingworx services?
xiaoqw
Hi, May I know how to use thingworx services to display this chart using label chart widget?
7 REPLIES 7
bot1q
11-Garnet
(To:xiaoqw)
If you want exacly the same chart. You need to build a custom widget.
xiaoqw
(To:bot1q)
Hi @bot1q ,
Actually, I don's want exactly same chart. I just want bar chart only. Do you have any suggestion?
bot1q
11-Garnet
(To:xiaoqw)
Please have a look into this link:
Barcgart
There is a videotutorial. This you can manage without doing an extra widget.
Or look at this Post:
https://community.ptc.com/t5/ThingWorx-Developers/Creating-a-barchart/td-p/522729
xiaoqw
(To:bot1q)
Hmmm,
actually I want coding about this chart. Like how to do using services in details.
bot1q
11-Garnet
(To:xiaoqw)
Sorry i do not understand:
You want to use the Basic Label (Bar) Chart and your question is how to bind the Data with services to this chart?
xiaoqw
(To:bot1q)
my question is how to coding and can show the result like this, using group by function, aggregate function, etc.
bot1q
11-Garnet
(To:xiaoqw)
You can not show the way without building a custom Widget:
I usually use https://plot.ly/javascript/ and build an custom widget from this to display the charts.
If you want a detailed explaination how to Code this Widget: Go to Thingworx Repository on your instalation drive open the Barchart and look how you can extende this chart.
