I have a requirement to implement customized login page,I tried to customize Thingworx FormLogin but it was not upto my requirement. Need suggestions Thank you
Hi @ashokq not sure if you have already tried this knowledge base article How to customize login page in ThingWorx.
Hello @supandey
Thanks for you are response,I had an idea about this.But when i change the login page it will effects globally,In my case i need to implement this for particular organisation only. That is the reason i choose this to implement customize login using thingworx,I designed mashup and trying to implement Login functionality.
Have you tried setting your Login mashup as the Home mashup of the Organization. I haven't tried it, but i believe the Home mashup will be used as the Login page for Users under that Organization.
Hello @unnikrisvp
We already set home mashup for the organisation, My issue is we will provide login functionality user with his username and password able to login and access the features,Exactly like Thingworx form login
The reason why i implementing the custom login is we are unable customize Thingworx form login for particular organisation.
