Hello everyone,
I was wondering if it's possible to change the min and max limit of an InRange alert that I have defined on a property (from a script). I was able to do this for an Above and Below alert but can't get it to work with an InRange alert type.
Thanks in advance!
Ok I have already found the solution I was using the wrong data shape for updating the alert values.
