I have saved image in local system and I want to pass this image URL in source URL of image widget. So how can i do it?
Khushboo Jain
So either you can input source file url like something from web - https://images.all-free-download.com/images/graphicthumb/australia_satin_bower_bird_bird_221260.jpg
or if there is any image in local ,you can create a media entity using it from the composer and then you can attach media entity in the source url setting also .
Thanks ,
Mukul Narang
Thanks ,
Mukul Narang
Hi @khushboo_jain.
If the response provided by @khushboo_jain answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
